Interesting Tow Test comparing new Ranger 2.0 to Old 3.2
- Hedgehog
- Has thanked: 66 times
- Been thanked: 72 times
As far as I know, they are two different engines. The volksie does not have the same engine as the frod
81.0 by 95.5 millimetres bore and stroke for the Dub
and 84.01 x 90.03 for the blue badged one
- Hedgehog
Why would it make sense Neil? The figures point to a different outcome to be had..
I think its more the fact that the gearbox had less ratios to think about, and this gave the engine time to build boost? My theory no 1
The other is that the smaller engine cannot generate the same plane of torque (more peaky) and this might then cause gearbox confusion.
Dunno, I would love to try them both back to back with my Commander in tow
- XJ Junkie
Even with my smaller diesel motor I see a massive increase in consumption under load, whereas larger cc diesels are less susceptible to higher consumption because they don’t have to work as hard.
- Has thanked: 111 times
- Been thanked: 147 times
No Andrewvandustbinhog, I'm perfectly fine.
I don't own a Ranger.
HAHAHAHAHAHAHAHAHAHAHAHAHAHA
Ford will sodomize you if you do this. Nevermind getting the computers to not throw a hissy fit.
