Has thanked: 381 times
Been thanked: 283 times
Posts: 1544 Joined: Tue Apr 03, 2018 4:01 pm
Post
by Paul#25 » Tue Apr 16, 2019 4:13 pm
Pointless exercise in destruction in my opinion. Bugger all real life scenario that I can think of that it mirrors.
Has thanked: 5 times
Been thanked: 1 time
Posts: 402 Joined: Tue Apr 03, 2018 2:41 pm
Post
by Oppies3800 » Tue Apr 16, 2019 4:33 pm
Steel
Can hammer it straight if needs be
wolley
Posts: 22 Joined: Thu Dec 06, 2018 5:23 am
Post
by wolley » Tue Apr 16, 2019 9:14 pm
The test is not relevant
Has thanked: 610 times
Been thanked: 257 times
Posts: 1766 Joined: Tue Apr 03, 2018 3:40 pm
Post
by Ricof4e » Wed Apr 17, 2019 7:26 am
Paul#25 wrote: ↑ Tue Apr 16, 2019 4:13 pm
I disagree. Its good to know the pressure tolerances between the two and how they react differently under pressure.
It can easily be applied to real life scenarios.
For instance, you will get a good idea what will happen to your rim if you drive at 80kph with a two ton vehicle and hit a deep pothole etc.
The video demonstrates the structural integrity between the two when pressure is applied.
The only issue I have (with their methodology) is that pressure is applied slowly but surely.
Post
by Ricof4e » Wed Apr 17, 2019 7:28 am
Oppies3800 wrote: ↑ Tue Apr 16, 2019 4:33 pm
Steel
I too prefer steel. But its ugly as hell.
Panda
Has thanked: 2 times
Been thanked: 4 times
Posts: 166 Joined: Mon Apr 23, 2018 12:26 pm
Post
by Panda » Wed Apr 17, 2019 8:09 am
Ricoffy wrote: ↑ Wed Apr 17, 2019 7:28 am
Steel
I do not have a issue with the looks, the weight is more of a concern, when i went to steelies on my Jimny it killed it instantly. but with 40Wkw it is to be expected
Posts: 809 Joined: Sun Apr 01, 2018 2:40 pm
Post
by Apocalypse » Wed Apr 17, 2019 11:02 am
The problem really is that you get different strength alloy wheels and steel wheels.
A steel rim as fitted to a citigolf will buckle in the presence of a 'morning after a heavy curry and 3 bottles of red wine' fart.
The steel rim fitted to a 100ton tipper truck is made of much sterner stuff.
Same goes for Alloys, there are different alloys as well as different wheel designs. Again, a rim fitted to an F1 car isn't the most robust alloy structure in the world, but they also make Alloy Rims for prime mover trucks.
so the video doesn't really tell the story unfortunately...
Posts: 949 Joined: Sun Apr 01, 2018 7:32 pm
Post
by ThysleRoux » Wed Apr 17, 2019 3:30 pm
Well said Alex. I have also found that certain "alloy" rims are actually heavier than similar sized steel rims and have only aesthetic value.
FLEX is UNDERRATED
Has thanked: 43 times
Been thanked: 81 times
Posts: 1460 Joined: Sun Apr 08, 2018 7:22 am
Post
by Mike Nel » Wed Apr 17, 2019 7:01 pm
These are the rims that are on my LC 200. They are steel. I don’t think they are bad looking...
