Land Rover P38 Gearbox Removal
Crips
Post by Crips »
Hi All
I need to remove the Gearbox on my 1996 P38 4.6.
It leaking oil out of the round inspection hole on the bellhousing.
I stopped driving it immediately.
Apparently it's either the input shaft seal or a cracked torque converter?
I'll be doing it myself, any suggestions or tips and tricks seeing that it is a Auto?
Cheers
Chris
1999 Jurgens Explorer
Anthony Forgey
Has thanked: 70 times
Been thanked: 65 times
Post by Anthony Forgey »
Tip #1
Don't do it yourself ;)
Tip #2 - listen to Anthony !
Tip #3: listen to Alex
Erin
Has thanked: 38 times
Been thanked: 62 times
Post by Erin »
Bunch of pansies...removing the gearbox is easy.
Putting it back right can be a pig of a job though...got that T-shirt.
Remove the motor and 'box as a unit ................ much easier to line everything up afterwards if you are not lying on your back under the vehicle
why not remove box and then
give it to Sean O’Reilly at
Gearbox Co to fix and reinstall ...
... at least you can save
on dropping the box ...
ask for quote estimates first :
remove
refurb
re-install
Total
Estee
Post by Estee »
Tip #4: Dont listen to Erin or Thys
Bunch of Ninnies with no sense of adventure. The Voortrekkers would not have reached the Elsieskraal river with you lot !!!!
Has thanked: 377 times
Been thanked: 275 times
Especially if their gearbox was broken.........
Prof
Has thanked: 15 times
Been thanked: 19 times
Post by Prof »
What I found wtih DIY...you have a better appreciation of your vehicle.....and second time around is so much easier
Crips
Post by Crips »
Tried to remove the prop shafts, took me half a day as the bolts where stripped.
So I stripped my moer
Phoned a Indy Landy guy who fetched her on Saturday, they will sort it out...
Chris
... on my RRC and defender the
UJ nuts on prop are specific ...
nylocks, (HT? ) and coned at top so
flat (7/16th?) spanner can get in
and turn them about 1/8th turn
at a time ...
none of my ring-spanners etc
can get in those tight places ...
... and not metric
Crips
Post by Crips »
Mon May 27, 2019 12:26 pm
at a time ...
... and not metric
These are similar but it's 14mm.
Also had to use a ring spanner but for the front prop where it connect to the TC you have to use a socket or remove the cross member, hence I just gave up :x
Chris
Crips
Post by Crips »
Flex plate shattered, damaged the torque converter and gearbox oil pump.
Torque converter has been sent in for recon and gearbox sent to gearbox guy to sort out the oil pump.
Hoping to have her back by the end of the week or early next week. [emoji1303]
Chris
