Hydraulic handbrake vs cables..pro & cons
Ginger
Re: Hydraulic handbrake vs cables..pro & cons
Post by Ginger »
Yes.
Buy a 4x4
My advice is to buy a 4x4
Buy a Prius or VW Up because you won’t buy a 4x4
Craig it doesn’t need a handbrake. Just switch the aircon on. It’ll lock the wheels.
Does it have an aircon?
With a hydraulic setup when the handbrake is on, the system is always under pressure. I don't think that is good. What vehicles have hydraulic handbrakes?
Cons: it’s illegal. It doesn’t work.
Pros: it works (for a while), then a con, it looses pressure, and then it doesn’t work anymore....
Has thanked: 319 times
Been thanked: 27 times
Drifting cars use them . Go look at their setups !
Johannes wrote:Drifting cars use them . Go look at their setups !
Maar dan is dit nie n “park brake” nie, maar eerder n “hand operated brake”.
N “park brake” mag nie hidrolies wees nie, want net een seeltjie op master of slaves silinder wat sweet, of inskroef konneksie wat sweet, en die stelsel verloor druk. So die voertuig staan geparkeer met hidroliese rem. Jy loop weg. Na enige iets van 2 min tot 48 uur, verloor dit stelselmatig druk, en voertuig loop reen bult af.
Drifting cars do use a hydraulic "hand" brake of sort called a cutting brake that operates on the rear wheels.
These operate much like a normal foot brake and don't stay locked when hand pressure is released.
You could fit something like this into the rear brake line.
https://www.amazon.com/Park-Lok-Univers ... B01N9VOQTJ
But as Reenen has already mentioned they are only as good as the seals you have fitted in your brake system and will bleed pressure over time.
As a temporary parking brake it would work quite well though.
