Fortuner Fridge & Ammo box slide/drawer system
I'm pondering building a removable rear sliding system for my Tuna (and a mates newer Tuna)
Does any one have pics of what they have done for ideas?
My second fridge is a NL 80 litre, but I suspect its actually too big for the purpose, what size 2nd fridges do you guys run?
Removable? Is this just for the fridge slides?
I made a flat 12mm covered marine ply base for the GX. I then added tie downs onto that for my ammo boxes. I also have a 90litre fridge slide on top of that. We take a 90litre fridge in the GX. We tried two 40 litre fridge, but they take up a lot more space
I will take photos later and post
Connect-it, chromadek and carpeting. Easy [emoji1303]
I was thinking of downgrading my 80 litre National Luna fridge to a 52 litre due to space, Initially I want just the slides & trays, and I need it removable as I often use the jump seats & boot and it is an everyday car, I was thinking 12mm MDF, use the jump seat brackets on the floor with J-hooks to mount the board.
So very soon i will probably have a very good condition NL 80 litre fridge with baskets up for grabs...
Tue Jul 03, 2018 1:48 pm
Kurt, how did you mount it to the car permanently/so its safe?
I was thinking of using the same, just maybe 2mm ABS plastic sheeting as its a lot lighter then chromadek, and easier to cut
It’s mounted to the bolt holes that are used for the back seats that I removed, each car will be different but it is bolted down.
Here is the drawer I made for Mad Man, he had a Gobi-X fridge slide that he has not used so I enclosed it with some left over materials. It came out much nicer than my drawer I made because I used different carpeting material.
Lekker Kurt :D
Looks lekker Kurt!
Sent from my E6653 using Tapatalk
Sun Jul 08, 2018 5:06 pm
The Chairman thanks you!
Has thanked: 376 times
Been thanked: 38 times
The chairman must pay up !
He paid [emoji6]
:lol: :lol: :lol: :lol: Wow !! Because you got access to his bank ??
Johannes, Manny is a porra he only deals in cash and gives change in chappies [emoji6]
Fridge fits...
