TD5 Engine Cover : Pro’s and Cons
- Has thanked: 295 times
- Been thanked: 150 times
My 2002 Defender 130 has
a padded engine cover / shroud ,
fitted as standard over the engine block.
Various aspects relate:
cover on means
faster engine warm-up
less noise coming up through bonnet
better (designed) air circulation
etc etc
Some doubt the merits of the covers being used
in SA and remove them ...
Whats the thinking on this topic
and other considerations ?
... and whats the thinking on getting
the engine ‘ to temp’ faster after start-up
... is the designed cooling system - air/water/oil
working best with /without such cover In Africa ?
What do you guys do ?
cover on means
etc etc
- XJ Junkie
It appears that VW don’t believe in them. They were apparently going to fit engine covers to the old Amarok, but decided against it.
So only the new V6 needs them
- Crips
- Has thanked: 6 times
- Been thanked: 7 times
I have removed mine.
It makes it hard to spot a issue like a loose pipe or oil leak.
It is more noisy without and I have not really noticed a difference in temp.
I take mine to Landy Mega Centre and they also recommend removing it for temp and better access to spot a issue should something arise.
Chris
1999 Jurgens Explorer
- ThysleRoux
Engine covers are fitted by manufacturers to hide the crappy layout in the engine bay.
FLEX is UNDERRATED
FLEX is UNDERRATED
- Chris Stoffel
In the old days, before all these new electronic stuff, a engine was a thing of beauty. Now the engine is covered by pipes and wires. It looks like the undergrowth in a jungle. And the engine cover hides the mess.
Does it really help to make the engine warm up faster? I don't think so. I do think that engine cooling will be helped with the cover off.
Suzuki Jimny - Hobbit Car
- XJ Junkie
Are you suggesting that there’s a potential heating issue with the Amarok?Chris Stoffel wrote:I do think that engine cooling will be helped with the cover off.
- Crips
He is referring to the TD5 engine, which the thread is about. [emoji16]XJ Junkie wrote:Are you suggesting that there’s a potential heating issue with the Amarok?Chris Stoffel wrote:I do think that engine cooling will be helped with the cover off.
Chris
- Chris Stoffel
The fact that the Amarok do not have a engine cover on leads to the conclusion that there is indeed a potential heating problem.
It is not as if engine covers were unknown when the 2L Amarok came out.
