Guide: How to Rebead a Tyre
Saxj wrote:
Mon May 28, 2018 11:27 am
Fri May 25, 2018 9:32 am
Quack wrote: You’ve also done it before! I’m waiting for comments on propellants and lighters[emoji12]
It doesn’t work in practice. [emoji31]
It does work. Jacojeep rebeaded Shrek's tyre at Wolwekloof using a tin of spray paint and a lighter.
Yeah. I've seen many Youtube videos on it.
Personally, it's something I don't have the goons to do
It wasn't anything near as dramatic as some of the videos I've seen.
Was the wheel/tyre on or off the vehicle at the time?
I’m yet to see a video of it being done properly whilst still on the vehicle.
Quack
Post by Quack »
Technically it does work, but you need the dexterity of an octopus high on meths and wonga🤣
Once its seated you better be ready with a decent compressor and already removed the innards of the valve! Otherwise it will just cool down again and debead itself again!
Someone mentioned ratchet straps around the circumference of the tyre which has never failed me, I would stick to this method, will keep the accessor happier as well🤣
What a life?!?😜
Mon May 28, 2018 12:28 pm
On the vehicle.
Quack wrote:
Mon May 28, 2018 12:36 pm
XJ Junkie wrote:Technically it does work, but you need the dexterity of an octopus high on meths and wonga🤣
I think this describes Jaco quite well
XJ Junkie wrote: Once its seated you better be ready with a decent compressor and already removed the innards of the valve! Otherwise it will just cool down again and debead itself again!
I'm pretty sure he removed the valve first.
As mentioned, you won’t need ratchet straps following my method.
As far as the chemical method goes, it’s not practical, wise or particularly effective.
Again, not many videos of it working while on the vehicle. The tyre tends to go down straight away unless you know the exact amount to spray. You can’t regulate pressure with fire.
The reality is that dedeads mostly happen in mud or sand. So the bead first needs cleaning anyway. The other reality is that you very seldomly get a tyre totally free of the ground, especially in sand after jacking the vehicle.
https://youtu.be/YZ233ai__fA
Saxj wrote:
On the vehicle.
Got a video?
Mon May 28, 2018 1:56 pm
Saxj wrote:
On the vehicle.
Got a video?
Unfortunately not.
That’s the trend
Mon May 28, 2018 2:10 pm
That’s the trend
I'm usually driving, directing, recovering or fixing. No time for silly things like pictures and videos.
Ons het die naweek by Robertson wildebeest 2 gebeat met axe en ligteher. Een op voertuig, een van voertuig af.
Die een waar ons video geneem het, was gedebeat binne en buite, en het nie gewerk nie. Daai een moes ons afhaal, en trap dat die agterkant semi beat, en toe met my 160 liter kompressor gebeat.
Een van my vriende het vroer in laas week nuwe mags vir sy pajero gekry, en selfs op 1.1 bar het hulle bly debeat (sommer binne en buite gelyk).
Thanks Reenen. Can we see the video?
Jaco Jeep RIP
#44
Post by Jaco Jeep RIP »
I use a can of spray paint. Works all the time. Axe is also a good repellent. I only lift the vehicle to take pressure off the tyre.
Quack
#45
Post by Quack »
Jaco Jeep wrote:I use a can off spray paint. Works all the time. Axe are also a good repelint. I only lift the vehicle to take pesure off the tire.
Spraypaint? Rerig? Moerse gemors🤣
What a life?!?😜
