I may be confused...Apocalypse wrote: ↑Mon Jun 03, 2019 9:58 amTo work out Power from Torque is the same - we need to know distance and time. the distance in the torque figure has to be altered to give us a linear distance to work in the Power equation.
So to translate it from a rotational to a linear is pretty easy - the circumference of a wheel is 2 x pi x radius
In effect - by multiplying it out, you've now translated the figure to Energy. 2pi Nm(torque) = 1 Nm (Energy) = 1J
So, we now know Force x distance (for 1 revolution) and just need to add time to get to Watts.
We measure speed of work in a motor in rpm (generally)
so, to add that into the equation we must divide the rpm by 60 to get to seconds AND we must multiply by the number of revolutions in one second as our figure is only for 1 revolution.
we'd also like the figure to be in kW (not Watts) so we divide by 1000
so, the final equation to get from Torque to Power (metric) is:
Power = Torque x 2pi x rpm/60/1000
As Pi is constant as well as the 60 and 1000 we can shorten it to:
Power = Torque x rpm /9549
As can be deduced - High Torque at low rpm (e.g. A big Diesel making 500Nm at 1500rpm is making only78kW) can make the same power as a motor making low torque at high rpm e.g. a proper F1 motor that revs to 19000rpm but makes only 300Nm is making 597kW
Basically... for Manny ... This means... that for any rpm less than 9549 the Torque figure will be higher than the power figure
at 9549 rpm power figure and torque figure will be equal
And over 9549rpm the Power figure will be higher than the Torque figure.
Now hopefully I never have to see anyone declaring that you convert torque to power by using the stroke of the engine ever again!
Lets take the Toyota 86
Bore & stroke = 86mm x 86mm - Boxer motor
1998cc
147kW @ 7000rpm
205Nm @ 6400rpm
Applying your formulae;
205 x 6400/9549 = 137kW - but the 86 is claimed to produce 147kW.
Are you saying the Power (kW) at 6400 is 137kW?
Do I then used the power peak (rather than the Torque peak)in the formulae?
Like so; 205 x 7000/9549 = 150kW (closer to the claimed 147kW).
Let's do another one;
Lexus NX 300E
86mm x 86mm - Straight 4
1998cc
175kW @ 4800rpm
350Nm @ 1650rpm
Apply formulae: 350 x 1650/9549 = 60...
So lets use the power peak;
350 x 4800/9549 = 175kW
BINGO!!!
Right, last one:
Subaru WRX
86mm x 86mm Boxer
1998cc
Turbocharged
197kW @ 5600rpm
350Nm between 2400 & 5200rpm.
Formulae: 350Nm x 5600/9549 = 205kW (bit higher than claimed - but close enough).
So its Torque x Power (not Torque) peak rpm divided by 9549
Or have I messed it up?
