TPMS systems info needed
LesseW wrote:It’s all about the spare wheel…
Are you talking about your wife?
If one purchases a LC , one of the first things is typically to buy one of those monster back-bumpers that support two spare-wheel swing-arms and perhaps a wood-basket, or a few Jerries or a water canister etc etc
Might this change the metrics or not ?
P.S. this is a ‘ concede-able’ benefit of buying a LC … IMO.
Quick feedback.
I went with the TPMS system that Andreas suggested.
I have done almost 1000kms with them on my Bushlapa and thus far can report no issues. It does what it says on the box. The App is easy to use. I think even Manny would be able to use it.
It's not expensive.
FYI.
I went to Safari Centre before I purchased these to inquire about replacement sensors for my TireMoni system. At the end of the day the replacement/s would have cost the same as a new unit would have done. So TireMoni can go get stuffed
Nice to hear Mike. I have done about 10 000km with mine on the car and over 6000km on the trailer. No issues.
Question, will the app alert in the background or does the app need to be open and on screen to alert?
It alerts even when run in the background.
Wessie, did you not get an alert in the back ground when this happened?
Nice thing about the app is that you can keep it open and keep an eye on the vitals. Will help with noticing slow punctures even before the alarm sounds.
Mad Manny wrote:Wessie, did you not get an alert in the back ground when this happened?
I did, but tyre place also says that my tpms sensors are old and cause leaks on the valves….
Tue Feb 22, 2022 12:41 pm
Please go and post this photo in the following thread so that we can make fun of it:
viewtopic.php?f=19&t=652&hilit=bf+goodrich
Mike, die BFs het net n normale spyker in die band gekry… niks ongewoonds nie.
Ek het hom met BFs gekoop, my keuse sou eerder Pirelli at+ gewees het…. Beste waarde vir geld.
Nou kom donner jy die hele storie op met n spyker. En nie n goeie spyker nie 😉.
Sou nicer gewees het as die BF net pap geraak het omdat dit n kak tire is 😄
My lewe was verander a.g.v twee spykers....
Kyk wat het opgedaag by my....
Bly om nou batteryspanning, banddruk en yskastemperatuur te kan sien op een toepassing.
Renier_c
Post by Renier_c »
Baie mooi Wessel
