Show your vehicle’s flex
#121
Serious Flex there David!
Has thanked: 466 times
Been thanked: 116 times
#122
That Sani has had some serious work done to it over the years!
#123
Looking good BFree
david bfreesani
#124
Post by david bfreesani »
grips wrote:Looking good BFree
Thanks Christo. I need to tackle my pinion bearings urgently now. Did you have any luck finding those bearing numbers or specs for me?
david bfreesani
#125
HenriSteyn wrote:
Sun Sep 05, 2021 8:20 pm
My wife took some video yesterday of me messing about in the pit.
https://www.youtube.com/watch?v=72dSKx3zDK8
johnoosthuizen
#126
Post by johnoosthuizen »
johnoosthuizen wrote:Took a drive on the farm today... ImageImage
Sent from my Note 10 using Tapatalk
Some pics of today I'm adding... Will be the last for some time to come... ImageImageImage
#127
Mon Sep 06, 2021 3:13 pm
Do you have to go serve time...?
johnoosthuizen
#128
Nope.... Tyres need replacing and some suspension work to be done.... Also looking to do an engine conversion...
david bfreesani
#129
Managed to duff it today on the farm. Maxed out my 700mm breakover clearance and got myself stuck without traction. Lucky all soft sand, and it took me half an hour to dig the sand out under the belly dropping the wheels back onto the ground.
#130
david bfreesani wrote:
Mon Sep 06, 2021 12:07 am
Difficult call to make without the diff open as these bearings are quite expensive.
From what I have bearing pinion front 32306 taper roller and rear 32308 taper roller
Carrier bearing 32211
Has thanked: 44 times
Been thanked: 152 times
#131
With Spookspruit closing, this was one of my best memories, and shows the natural flex under difficult circumstances.
#132
… beyond my flex …
… probly the closest Ive come to rolling the Dreadnaught …
At 3-Provs going down a steep wet decline, the vehicle was tilting on diagonal wheels …
front right wheel sitting about 1/2m up a boulder
and back left wheel taking balance of weight,
front left wheel free-hanging & limp above sharp fall-off in in the decline so my bumper was ? maybe + 1.5 m above the road.
… see-sawing vehicle … needed a little help from my friends, until a Rubicon winched me back up-hill a bit so that I could proceed in more dignified manner …
#133
Chas, Jeeps and Jimny's refer to death wobble, Defender refers to death plunge.
#134
Martin de Jager wrote:
Sun Sep 12, 2021 11:12 am
… that predicament/line was way beyond
survival threshold of a Jimny
which would have rolled down the slope
like an over-ambitious but overwhelmed dung- beetle !
#135
Prado has little flex but With enough speed I do not need flex…
